Replacing speedometer with a used one
I didn't see anyone respond to this. Did you get an answer because I'm looking at the same model speedometer for my 09 flstn.
Used speedo 7900068a
These speedometer mate to the bike after installation and riding 25 miles. I bought the 068 part used but the seller assured me he'd done less than that and was spot on. Before buying I'd call either a dealer or HD to make sure the odometer will work. Miles are recorded on the speedo unit but it's also stored in the ECM I think after the mating is complete then you're done, can't reuse with another bike. The unit won't allow an overwrite of the mileage on it.
Love the unit thought the tach is helpful as is the gear indicator for when you're not tuned in.
QUOTE=B00merd;17650474]I didn't see anyone respond to this. Did you get an answer because I'm looking at the same model speedometer for my 09 flstn.[/QUOTE]
It is also possible to replace the LCD unit in the EVO speedometer. I saw some instructions on how to do it. Look in the EVO section of this forum. Way cheaper than my method. You might also be able to go the aftermarket route as well.
carl
smitty901 (06-19-2023)
I have used STOCK OEM speedos on "other" bikes a few times now. I have even put Softail speedos on Dynas and they worked.
Always within the parameters of a few model years. Not 10 years age different.
I used a 66,000 Kilometres unit in 3 different bikes and they all read 66,00 K's.
Hope that helps ya ?
oleksa (08-16-2024)
