Can someone explain what happened?
After about an hour of cruising, shut her off...decided to turn her around, went to restart, dead ignition. Had lights, but nothing fron the ignition, not even a click. Checked all connections, ignition wires. Started her with the plunger on the starter motor, then shut her off and restarted her at the key, no problem. Can someone please explain what happened? Its a new ignition switch, been working fine. New Crane module, single fire, dual coil.
Thanks,
zen
Thanks,
zen
ms3300
02-05-2014 04:59 PM
chopper.stud
07-20-2007 04:37 PM
