Molex Electrical connectors
RE: Molex Electrical connectors
What's a Molex connector? I ask because my '04 EG and my friend's '06 EG use Deutsch 12-place connectors for the handlebar wiring connectors (Connectors 22 and 24 on the '04 Service Manual wiring diagrams)and they don't require or need a special tool for pin, (actually the handlebarconnectors contain sockets and plug into an interconnect connector that has pins)removal.
ORIGINAL: skykingFLHTCU
I am installing wires through new Wild 1 bars. I am wanting to buy a tool for removing the pins on the 07 Molex connectors. HD-48114 # but nobody including Zanotti sells them. anybody using a trick aftermarket toll for these ?
I just emailed and asked for the price HD-48114 $ 36.85
Did you actually ask or just put the part number in?
These connector are very easy to work with. Remove the back side lock. Then the front white pin lock guard can be completely pulledout through thefront.Once you have that off just pop the pin releases and remove the pins. NOTE: the pin locks are built into the connector (not the pin as in the past).
When reassembling push the white pin lock in half way. Once all pins have been inserted, fully seat the white pin lock.
I finally got them done and am pretty good at it now. My mistake was reading the manuel first it said DO NOT remove secondary lock but pins can only be released with special tool. I as cjuetten mentioned, removed the entire plastic piece that manuel said not to. On second plug I removed it half way then used a paper clip as my special tool which worked.
Once again thanks for everyones help
Each Molex pin has a side with a longitudinal crease and a smooth side. Load the pins so the smooth side faces the middle of the connector and the crease side faces the outside of the connector. All the smooth sides should face each other. If you do that, the white block pops right down.
You should even be able to load all pins with the white block fully seated.
Certified Drunk
06-06-2009 11:46 AM
