Battery draining...
Battery draining...
Hi there,
Can anyone help? I have a customized HD Softail with simplied wiring system.
Just recently for the first time ever I used an external charger to charge my battery, since then the battery is not holding the current, even without riding, the battery will dead after 5 days. I suspect it could be a leak or something else. I am full charging the battery again and left it disconnected to the bike to see if the battery is holding the power after a few days. After replaced with another used battery, same happen so I suspect it must be something causing the leak after my first external charging. Now question:
- How do we know if there is a leak?
- How can we check or identify the cause of the leak?
Thanks. ZInq (Malaysia)
