Loss of fuel pump power and spark
2000 FLHRCI, 35k miles. On occasion, when I put the run switch in run, the fuel pump doesn't run nor do I have spark to the plugs. Eventually, with some digging around fuses, relays, connectors, etc. the problem will go away. Bike has a Power Commander III USB on it now for 20k miles and everything was fine until about a month ago. Once the bike starts, no issues.
My Indie checked fuel pump, run/stop switch, coil, tilt sensor, map sensor and crank position sensor. All good. I thought maybe bad ECM but after reading forums that seems to be quite rare.
Any ideas
Any ideas
glyates
04-06-2013 10:23 PM
