Disabling the security system?
Old 05-21-2007 | 06:21 PM
lbrty9's Avatar
lbrty9
Default Disabling the security system?
I can get my systm o de-arm only by using the manual security process with the turn signals. I've tried replacing the batteriers in both keyfobs and reprogramming. The fobs just never get recognized. I've tried programming in 2 different geographic loctions, so it isn't interference.
It's an 01 FLHRI and it does have a PCIII. Anyway, I have an appt with the stealership on Thu. In the meantime, anybdy know how to disable the security system... this is getting annoying! Took it today for a inspection and when I went to pull out, the system disarmed, but then they key started flashing like once a second and I had to sit there for like 5 minutes, looking like the dork that I am, and then it reset and started with the manual sequence.
Tampa Fatboy
06-15-2015 03:18 PM
P51Driver
07-30-2012 11:33 PM
Vol Fire Cap
01-26-2011 05:03 PM
Tom Carter
07-07-2009 04:51 AM
workformetoo
04-27-2008 09:53 AM
Quick Reply: Disabling the security system?
