Weird problem I can't figure out
Hi all, I hope somebody else here has had this problem and can help me out. My bike is a 2012 heritage, se aircleaner, Rush 2 into 1 pipes, Powervision tuner. My bike has ran flawlessly since it was new however, last week I was going about 60 and was coming to an intersection where I had to turn. So as I tried to blip the throttle to downshift, nothing. The engine just wanted to shutdown. I pumped the throttle and it spit and sputtered then came back to life. Ran fine for the rest of the day. Now its getting more and more frequent. Yesterday, I rode about 100 miles without issue then it came back. This time as it was happening I noticed the gauges on the powervision were all out of wack. Head temp was reading 60 degrees and everything else was bouncing all over the place. I shut it down and restarted it and all seemed fine. On the way home I stopped at a grocery store to get some steaks to grill. I came out, packed up my goodies and tried to start it. Nothing! Cranks over fine but no start. Strong smell of gas so I just let it sit for a bit while I had a cig. Tried again and it started as normal. Got me home and here I am. The gauges for the VE seem to be a bit odd too. Front running around 80 and the rear around 100. Anybody ever seen anything like this before? ECM Failing? Coil? I'm clueless. I kind of wish it would just fail so it would be obvious whats wrong. Thanks for reading.
