Engine Light
RE: Engine Light
ORIGINAL: im
#56 is common,
did you have a bad start ? with a back fire?
double check the wires for crank/cam position sensor.
look at the wires that go into the timer V2 cone on the right(throttle side)..anything melted?
if you do get the #56 most times it is a hick-up, erase and see if it repeats.
#56 is common,
RE: Engine Light
I tried this procedure last night and it did not work for me.[&o]
ORIGINAL: im
on my 1998 road king classic with fuel inj. you can read the codes doing the following:
1-turn ignition key switch to ignition and then turn off 1 second after fuel pump stops.
2.repeat #1 again..remember 1 second after pump stops
3.turn ignition key switch to ignition and wait about 8 seconds for a bunch of flashing of the check engine light
it will then stop for 2 seconds..get ready... these are the codes you must count:
it will slowly flash 1,2,3,5....there is NO 4....this is the first digit of the 2 digit code ..so it can only be 1,2,3,5 __ __
then a 2 second pause...then you will get second digit of the 2 digit code..it can only be 1,2,3,4,5,6
remember after the complete 2 digit code is given you will go back to the rapid flash sequence..
there are a total of 15 codes available with this procedure
examples
52,53,54,55 bad news ECM replacement
56 crank/cam sensor
11 throttle sensor
12 barometric
23 and 32 are injectors front/rear
24 coil
33 fuel pump relay--in this case you would not hear the pump but instead waited 3 seconds after the on / off sequence
in order to erase any codes you must disconnect the battery or wait for 50 on and off riding cycles
examples
56 crank/cam sensor
11 throttle sensor
12 barometric
24 coil
98 roadglide
09-10-2008 11:12 AM
