Do I need to change fuel injector??
Old 06-09-2016, 06:38 AM
robrory87's Avatar
robrory87
robrory87 is offline
6th Gear
Default Do I need to change fuel injector??
My 2011 883 is coming up with error code P0262 (front fuel injector high EFI)
Does this mean I may need to change it?
Point to note I did need to change my front o2 sensor as it was giving error code too, changed that part out clear the code and it just left me with the remaining P0262
PLEASE HELP 😫 The weather is good and I wanna ride
Old 06-09-2016, 07:00 AM
nhrider1's Avatar
nhrider1
nhrider1 is offline
Check the wiring to the front injector. Look for shorts or breaks. You may need to wiggle the wire as they sometimes break under the insulation.
If you can't find a problem, replace the injector.
Old 06-09-2016, 08:09 AM
hrdtail78's Avatar
hrdtail78
hrdtail78 is offline
Veteran: Marine Corp
Yu can also swap injectors from front to rear and see if the problem follows the injector or stays. If it follows, you know it's injector. If it stays, look for chaffed wires, pulled pins at injector connector and ECM plug.
Old 06-09-2016, 09:15 AM
robrory87's Avatar
robrory87
6th Gear
Ok I'll give these things a try. How difficult is it to access the fuel injectors, looks like I may have to remove the tank which a seems quite tricky, I'm a novice but trying to learn as I go.
Thanks
Old 06-09-2016, 09:18 AM
robrory87's Avatar
robrory87
6th Gear
Thanks
Old 06-09-2016, 04:51 PM
robrory87's Avatar
robrory87
6th Gear
Ok so stripped the bike down, but I'm having trouble getting the injectors out, how do I remove them ?
Old 06-09-2016, 10:09 PM
RKGDCG03's Avatar
RKGDCG03
RKGDCG03 is online now
Veteran: Coast Guard
Service manual??
Old 06-10-2016, 05:27 AM
robrory87's Avatar
robrory87
6th Gear
Originally Posted by RKGDCG03
Service manual??
Yep so the fuel injects just pop out 😂
Old 06-10-2016, 05:46 AM
robrory87's Avatar
robrory87
6th Gear
Ok so swapped the fuel injectors and still the same fault. So I'm guessing the injectors are fine and the fault must lying with the wiring somewhere
Old 06-10-2016, 06:26 AM
robrory87's Avatar
robrory87
6th Gear
UPDATE
Using a multi meter I've found it's a wiring issue from the front injector Y split cable (not sure if the technical name) but it seem a simple fix, either buy a new cable or a new wire and Mend the dodgy connection.
Quick Reply: Do I need to change fuel injector??
