Do I need to change fuel injector??
Old 06-10-2016, 09:59 AM
hrdtail78's Avatar
hrdtail78
hrdtail78 is offline
Veteran: Marine Corp
Originally Posted by robrory87
UPDATE
Using a multi meter I've found it's a wiring issue from the front injector Y split cable (not sure if the technical name) but it seem a simple fix, either buy a new cable or a new wire and Mend the dodgy connection.
Sounds good.
Old 06-10-2016, 10:22 AM
robrory87's Avatar
robrory87
robrory87 is offline
6th Gear
Originally Posted by hrdtail78
Sounds good.
So I took the wiring off and before I started stripping wires down and replacing etc I gave the continuity another test and it appeared fine. I realised I made a mistake testing the wiring before hand. So injectors are fine and fuel injection wiring system fine. So now I'm really confused. Could it have something to with the ECM?
Old 06-10-2016, 10:55 AM
robrory87's Avatar
robrory87
6th Gear
Sounds good.
One thing to note when I open the throttle up the warning light goes off and the front cylinder then starts to fire. I can feel it start to heart up. As soon as it drops back to idle, the check engine light comes back on
jcolleymx
Electrical/Lighting/Alarm
07-29-2021 04:02 PM
alexb15ms
07-12-2021 08:46 PM
cavemansean
12-11-2017 11:42 AM
johnye75
04-02-2010 03:04 AM
Cynic
07-07-2007 12:16 PM
Quick Reply: Do I need to change fuel injector??
