Retune: Use Map in ECM or use a Canned
Question for tuners:
1. Suppose a customer has you tune his bike. Then a year later he swaps out the TB body and exhaust. When he returns to you, would you use the map you tune his engine before or would you download a canned map to work off.
2. Suppose one tuner tunes an ECM. Then customer on a road trip wants another tuner to check the map and tweak as necessary. Would the new tuner look at map and tweak if possible or would tuner download a canned map to tune off it? Perhaps customer has decal pop or getting less gas mileage and would just like a different tuner to look at the map.
I'm no professional tuner, I can tell you what happened 3 times I had my one build on the dyno by 3 different tuners. The 1st tune was done by what the locals called the best guy for a tune, he sucked. Bike ran hot and pinged. Took the bike to a different tuner, he wasn't interested in the previous dyno tuned map, he wanted to start from a clean slate. A couple years later I had another person tune it because I thought it could be just a little bit better. He also wasn't the least interested in the previous map, he also wanted to choose the starting map and work from scratch.
All 3 times the same base map was chosen by 3 different tuners. It's easier to roll your own vs figure out all the changes someone else made to the other tables when someone else tuned the bike last.
Msocko3 so three tuners same build.... did you see any difference on the dyno printout with TQ curve between the three? And they probably didn’t print off the air/fuel ratio. I don’t understand how one tune can be that far off that another tuner can’t tweak it.
I don’t get it, I took my bike back to a tuner two years, he tuned it, bike ran exceptionally well and got good mpg. I did a TB and exhaust change, went to the same tuner and he built a new map using a canned map. IMHO, I would have thought he could just have used the previous map. Now my bike runs well, but I think it can be tweaked to get a little more out of it, at least check all the parameters within TTS.
I’ll have to buy a Windows laptop to check and maybe try to tweak myself.
He is a very skilled tuner. Just curious as to what other tuners might do in the same scenario regarding previous map, especially if minor changes were done to engine. Not like going from 95” tune to 107” tune.
I heard the guy mentioned toward the end of Post #7 on the following link is decent.
http://www.roadglide.org/26-engine-r...er-needed.html
TexasMotorcycleRider
The Dyno Room
30
05-29-2019 11:35 AM
chrysleintz
05-16-2008 05:17 AM
