Fuel Moto maps, how close are they?
Bike is a 2015 Street Bob with Two Brothers Comp-V intake, Two Brothers Comp-S 2-1 exhaust, and SE255 cams with a base map from Fuel Moto for my Power Vision. I've heard their base maps are pretty darn close as is, but I ran 4 autotune sessions using autotune basic the other day just to see what they would produce. I was quite surprised at how much my VEs were off. The front cylinder was worse than the rear, but even the rear had a few cells that were more than 20% off. Is it normal for Fuel Moto's maps to be this far off, or is there something else going on here? I attached some screen shots of WinPV software showing the delta in VEs from the base map to the last autotune run for both cylinders.
The VE's will always be somewhat off. I wouldn't worry about it if it tunes up in 4 or 5 runs. The plus side is you probably won't need to do much with the timing from Fuel Moto. Don't make this more complicated than it is. It seems like this thread has gone downhill in the last year or so. Allot of guessing and a few people trying to do things with the PV that they will never be able to measure. It was never designed to do much more than VE's, a guess at timing, and a few simple table changes. Don't get caught up in the trap that has evolved here and think you will create the tune of all tunes. It just isn't going to happen, but you can get close and end up with a nice running bike. I have yet to have a trouble tune from FM. And, yes I have had areas that changed 20%. But that was the first run. After 4 or 5 I was within 3%.
Having a good map as the foundation to start with is important, however having the tools and resources is paramount, as is a willingness to learn. This includes the correct tuning product & hardware for the job as well as the availability of technical support should it come necessary.
I would be more than happy to review your PV calibration and any logs you have, there should be no trouble getting your combination tuned in. If you need any assistance all channels are open and we are here to help.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
There is no blanket statement or guideline on how much a base map will vary since there is literally an endless amount of combinations as well as various differences in production tolerances,etc.. however it really comes down to the how close the specific base map is to the exact combination you are working with and having the ability to fine tune it. In your example i can tell you that the base map we supplied was for the SE255 cams in a 103" Dyna but for a slighly different exhaust, VE delta's of 20% are not really out of the ordinary, and from what i can see it appears you have Pretty solid correction data from Auto Tune Basic. This is going be normal, for reference you may see 15% or more tuning a completely stock bike with the even the oem calibration just as it rolled out of the Motor Company. Also remember you also have normal closed loop for live fuel correction, Auto Tune Basic is simply taking selective data to populate corrections and applying them back to the base tune.
I'm fairly new to auto tuning. How did you get those tables showing the VE changes imported into WinPV so that you could see those changes?
Thanks.
http://dynojet.com/powervision/powervision-faqs.aspx#4d
How can I compare two different tunes?
There is a feature in the WinPV software to compare two different tunes. Once you have a tune open in WinPV, you can select the icon to Load Compare. This will prompt you to select a tune that is already saved on the computer; you cannot select a tune from a Power Vision. Once the compare tune is opened, the software will highlight the fields that are different between the two tunes. You can switch back and forth and see both tunes, or you can see the Delta, which is the difference between the two.
kryingame (04-01-2016)
I'm sorry that I got shitty with you on several prior PV posts. I apologize. I was frustrated. I was wrong and shouldn't have posted such.
I appreciate you responding and helping me out.
Mr. Wizard (03-30-2016)
agove
16
04-09-2013 03:23 PM
