Monitoring actual AFR with a Power Vision.
Like the title says. I want to monitor the actual AFR. I see on the list of gauges there is set AFR. I am assuming that tells me the AFR that is set in the AFR tables. Then I see WBO2. I assume that is wide band o2. I am running narrow band o2 sensors. When I select WBO2 it reads anywhere from 10.5 to 12.0. I am going to assume again the reason it is lower then what I have set is because of the VE tables. Am I understanding this correctly or since I am running narrow band sensors WBO2 is not reading right? Thanks!
Don't think you can monitor AFR with Narrow Band O2. Look at 1:38 in this video
http://blogs.dynojet.com/index.php/2...n-gauge-setup/
Received 49,886 Likes
Not sure how accurate with narrow band sensors. I have my cruise range set to 14.6. The power vision gauge says 11.9. Not sure if my o2 sensors are bad are the power vision is not reading it right since it is narrow band sensors. Have not been able to get a answer.
You cannot read live AFR with the factory O2 sensors, narrowband O2 sensors do not report air/fuel they report 0-1 volts. Also note various ECM's and tune strategies use different voltage offsets.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
