Power Commander 3 help
Map help.
I have 03 Ultra, 88" motor, screamin eagle air filter and cvo mufflers. I am looking for a map to run that is comparable to this set up.
I have called Power Commander and every tech I talk to gives a completely different map. The maps seem a little rich according to plugs.
I have also tried Fuel Moto twice, both times put on hold and then disconnected after a minute or two. Not very impressed by them so far.
Seems like I will have to make adjustments to any map, hoping just to download and go.
Thanks.
Thanks.
Did you buy it from Fuel Moto? if not they will not supply you with one.
If you did it is best to email them the request with your specs.
I have received maps from them after emailing them the info but I did get
my PCV from them.
Have you tried to download any from Power Commanders site yet picking
the options you have with the drop down menus?
http://www.powercommander.com/powerc...ap_lookup.aspx
my PCV from them.
If your bike is stock with those mods and you have a PC3, you'll probably get better results by starting with a zero map, adding a couple of degrees of timing and perhaps bumping the buttons rich one light across the board. That setup doesn't require anything exotic, and screwing around with map after map in email is most likely wasting your time.
