Switching my 99 MM FI
RE: Switching my 99 MM FI
ORIGINAL: PosseRider
If ya need a throttle body, I have 2 Dephi's . One is NEW & one is used. $300 new & $175 used + shp. They are $609 new from HD Both have all sensors & injectors.
Just keep in mind that those Delphi TBs run off one fuel line. Your M&M has two fuel lines, and the inside the tank fuel pump and guts are different. So unless you want to change all that out, tank, tank guts, and lines, the easist thing to do is get the Thayer TB, which is Delphi, but has been modified to accept your dual fuel line tank, and the fuel pump pressures too. Or go with the Zippers kit which is a Zippers ECM, and modified Zippers 50mm TB. In any event, the best part is you get to keep your tank, and don't have to worry about color matching.
