Battery Charging
Battery Charging
I use a battery tender on my bike when ever it is parked in my garage. My question is why does the battery tender always show "charging" when I plug it in even after long rides? I have checked the charging at the battery while the bike is running "14.25"
The tender will show charging for approx 1 hour then switch to storage mode.
RE: Battery Charging
As I understand it the Battery Tender will always go through its 3 or 4 cycles of charging when you first connect it. I have always used them on my bikes when they are in the garage - as soon as I get home the charger gets plugged in. Even when I have been on the highway for miles and get home and connect it it goes through the flashing stage before going to steady green. I belive this is totally normal.
