V&H Big shot duals & pcIII
Hi all I am new to this forum and thought maybe the pcIII gurus could help me out. I have a 04 road glide with a se ac/ ecm stage 1 chip burn/ and se pipes. I am going to put on a pcIII and the V&H big shot duals. I can not find that combo with se ac/ V&H big shot duals/ and stage 1 ecm.. Does anyone have any suggetions as to a map #? Thanks for any advice!!
RE: V&H Big shot duals & pcIII
This is just a guess but it looks like the closest to your setup is M807-170. You can use any map for a PC3, it doesn't care, it just adjusts fuel and timing. I compared alot of maps before I started with the one I have, it was still too rich for my riding style. I'm happy with the tune I have and no popping, good gas mileage also.
It should be on the disc that came with the PC3. Try this site it will take you there, http://www.powercommander.com/powerc...b/default.aspx or try here to find the touring maps, http://www.powercommander.com/powerc...31&yr=2004 I just looked again and they have a map for the exact setup you have, it's M807-178.
lionsqrne
09-18-2008 02:12 PM
MDodson
10-20-2007 07:56 PM
