Stage 1 Upgrade! Tuner or Have it Dyno Tuned?
So I'm going to upgrade my 2015 Road King with a fuel moto X-pipe, Rinehart 4" slip ons and breather upgrade. Are most all dealerships the same price on Dyno Tuning or would a Tuner be better. I know the bikes come from the factory lean. I guess I'm just confused on how these systems work. I figure if it has a way to map the air/fuel mixture why do they have to be tuned with just a stage 1? Is the window on the map too small for self adjustment? The way it sounds when you buy a new bike you should have it tuned to run more efficient.
Thanks,
Critter
Thanks,
Critter
Depends on how good your dealer is at tuning. I get mine tuned at the dealer because they're pretty good at it. Also, my dealer will back their work.
They have to be tuned for a stage 1 because you are letting more air in and with the stock fuel mixture, you'll run event hotter.
I've used an on-the-fly tuner that worked well. Some kits have pre-defined maps that work almost as well.
ok glad we have that cleared up, I thought it was one or the other.
when it comes to tuners do most guys like the on board tuners or a tuner that just flashes your computer?
