SERT Tuning Experts - Up for the challenge
OK, your mission if you choose to accept it is to help me figure out if possible how to get rid of a decel pop. It occurs in an engine braking type event when the RPMS are varying between 2300-2600. Usually it will happen if my rpm's are steady around 2600 and I left off the gas in a lower gear. I have added fuel from the enleanment tables (decrementing)between 96-128c and that did not seem to help. My tuner has maxed fuel between 2000-3000 rpm's in TP zero (incremented up with minor success). I understand that the injectors kick in around 2500 rpm but I don't know how that effect enleanment or if it is worth trying to modify this table any more.
Thoughts?
Thoughts?
RE: SERT Tuning Experts - Up for the challenge
Decel enleanment only affects throttle roll off.
In VE you can manipulate up and down in the 0 and 2% columns as well as spark where the injectors turn back on.
You don't mention your combination/pipes.
The key is to make it either burn before the pipe or make it non combustible in the pipe.
I just have RhineHart True Duals and a Big Sucker.
Also, this even does not occur with any throttle left; meaning that it happens just at zero. I am at that for at least .5 second before it occurs.
I don't really want to mess anything up on the mapping as I have it tuned to almost perfection with the exception of this annoying pop that occurs every so often. Maybe it is not even possible to tune it out...
Chris07
10-11-2013 11:59 AM
TickTock
16
06-18-2007 10:52 PM
TickTock
11
05-02-2007 03:05 PM
