Ultima Single Fire Ignition Kit # 53-61
I have the Ultima Single Fire Ignition Kit # 53-61.
I also purchased the Dynatek Coil DC6-5 Twin Fire Mini Coil.
Single Fire Ignition Kit # 53-61 PDF file: http://www.ultimaproducts.com/ignite.htmscroll down a bit.
Twinfire Coil: http://www.dynaonline.com/english/harley_coils-mini.htm
DC6-5 Twinfire PDF file listed to the right under Coils: http://www.dynaonline.com/english/guides.htm
I'm going to install this on a 1995 FLHT.
My question is this, when routing the wires from the Single Fire Ignition Kit # 53-61 to the VOES/Tach/Coil do I leave the stock wires on their connectorsand install the wires from the # 53-61 with the stock wires ?
To me this does not seem right since I will be eliminating the plug that the old ignition plugs into .
Anyone have an idea, this setup is very similar to the Crane and Dynatek setup's.
Thank you in advance.
RE: Ultima Single Fire Ignition Kit # 53-61
i have most of it figured out except for the VOES switch, I have a Violet/White and Black wire going into the connector before the VOES switch, then from the connectorthere are two Black wires going into the VOES switch.
Sooooooo most of the references I see only mention a single Purple wire going into the VOES.
Found it, I simply connect the Green wire from the Ignition to where the old Violet/White wire was, the black wire is ground. [sm=happy046.gif]
