Power Commander 5 vs Target Tune
I have been really impressed with the newest Target Tune stuff. A standard PC5 is not even close. Add a POD-300 and a Autotune/Wideband to the PC5, you are getting similar ability but the Target Tune setup is a way cleaner package. Target Tune my have totally obsoleted every other option in the Harley world. It appears to be that good.
The guys at www.FuelMotoUSA.com can fix you right up.
Hope this helps
Andy
Hope this helps
Andy
PC5 with AutoTune lets you AutoTune with WB O2 sensors. Target Tune allows you to do the same plus:
- Allows the factory ECM to interpret and use wideband O2 sensor signals*
- User defined AFR/Lambda targets over a broad range
- Target fuel table from PV calibration is achieved in real time
- Retains OEM closed loop, adaptive fuel control strategy
- Learns and uses VE table corrections as you ride
fuelmoto
Vendor For Sale Classifieds
04-04-2018 10:16 AM
fuelmoto
Fuel Moto / Jackpot Mufflers
02-22-2018 01:08 PM
