SERT Dialing in the last bit of decel pop
Old 05-02-2007, 01:42 PM
murphdog's Avatar
murphdog
murphdog is offline
Default RE: SERT Dialing in the last bit of decel pop
Tick, I believe that's what I'd do if you're sure everything else that would matter is the same.
I'm sure you're aware that you can do a "compare edits to reference" and see everything that's been changed from the original map.Also, that you can highlight cells or a whole table and click "set reference" to put everything back to original values.
Old 05-02-2007, 03:05 PM
TickTock's Avatar
TickTock
TickTock is offline
Thanks - and I don't know. I wasn't planning to mess with this thing because it is pretty complex and quite honestly I don't have time to really learn it. But... I have less time to go back to the tuner for the minor tweaks. I spoke with him earlier this morning and he is willing to make adjustments but he didn't feel like it would help based on his past experience. Regardless, I am going to buy some cables and work to figure it out as best I can.
HD4GD
03-13-2009 02:33 PM
TickTock
11
08-07-2007 07:24 PM
TickTock
08-03-2007 10:29 PM
07_103_NT
07-17-2007 07:23 PM
TickTock
05-06-2007 02:39 PM
Quick Reply: SERT Dialing in the last bit of decel pop
