Starting Problems
Starting Problems
I have just purchased a 2004 Road Glide and am experiancing an intermittent starting problem. Most times it starts fine but once in a while when i push the start button all I get is a click in the solenoid. I have changed the battery and had the same problem, then put back the original battery and it started. All the other times I have experianced the problem I do nothing but keep trying it after a few mins it will start. I have brought it to a Harley dealer and they say they can find nothing wrong, after tightening the battery terminals.
A few times when it did not start I checked the terminals at the battery and at the starter and they are tight. Does anyone have any suggestions?
Tim
Tim
RE: Starting Problems
Starting problems like you describe usually come from bad battery connections, and don't forget there's two ends to those cables that need cleaning. The starter solenoid could be a source as could the starter relay. It's a matter of diagnosing the proper source before changing parts.
I have removed the starter relay from it's mounted position and held it in my hand and can feel it clicking ( I'm assuming pulling in) while experiancing the starting problem. Do you think this indicates the relay is good? Is it true that the solenoid either works or not and could not be an intermittent problem? When I experiance this problem again I plan on checking the voltage at the starter. if I have 12 volts can I assume all connections up to that point are good and that the issue is solenoid or starter related.
Tim
Tim
ORIGINAL: ackmoe
Tim
Tim
I just fixed my starting problem. The starter would engage, start to turn over and then stop. After several attempts it may finally work, sometimes I had to put it in gear, pull in the clutch, wait for the starter to engage and push the bike forward. I tried all the usual stuff with the battery and cables (they were new) and even attached a large car battery directly to the starter with pro jumper cables.
The starter is a new 1.6 kw and my engine is a stock Evo, this should work fine, even better than fine. I have been conversing with the vendor (starter under warranty) but he wanted me to ship the starter to him and he would replace it. I live less than 100 miles from the guy and he would not let me drive it up to him to reduce my down time. He had all kinds of excuses.
Well last night I had the primary apart fixing a leak and pulled the starter too. I decided to open the starter and look at the brushes. The comm looked like it had been prepped with 100 grit sand paper or worse. Sure enough, one of the four brush hoods were bent and causing the brush to hang. I fixed the hood, prepped the brushes and comm with 1000 grit wet and dry, now the starter turns my engine over faster than ever.
Emailed the vendor and told him what I found and did. He says he is sending me $20 for my time and effort and will still honor the warranty. Don't try that with just any vendor.
[sm=yeahsmile.gif]
[sm=yeahsmile.gif]
