Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Putting together a 107, 10:1, Stage 2 heads, SE 50 mm throttle body with 4.9gram injectors, Andrews 57's, true duals with CFR's. Looking for a map for Power Vision.
I have one for a 107 with woods 777 cams with level B heads and the SE 50 mm and the 4.9's. Not sure how similar the cams are but I can email you it if ya need
I called Dynojet and they wrote me a map wrote me a map for my setup that would get me going and I could either auto tune or Dyno it. Thanks for the offer on your 107 map I appreciate it.
