ingition switch help
1989 Harley Davidson ultra classic electra glide flhtcu
My ignition switch won't turn off everything when it's in the off position it has to be in the fork lock position but the forks won't lock but to start the bike it starts in the ignition position and also when you use the key to lock the switch you can move the switch back and forth still unless you move it to the far right to the accessory position then it locks. Any ideas?
FunkyNova66
09-26-2009 07:32 AM
