backfiring, jerking forward, stalling, speedo jumpimg
o codes showing.
I broke down a dozen times on the way to a bikeshow, the bike kept jerking popping and stalling, and when it stalled it let out a smelly fart finaaly made it to H/D and they could not find problem after 5 hours, they put in a new ECM and took off my powercommander. They said I have 60lbs of fuel pressure.
I'm down to a speed sensor or crank position sensor, can they go bad without flashing a code? I already drained the tank and put fresh gas in it, changed plugs. Battery terminals are tight. It is almost like a interruption of combustion, when it happens the speedometer will go from 60 to 10 then jump back to 60 while jerking forward, popping then stalls. I have not gone inside the tank yet.
Any input would be appreciated.
2006 SB. Vanve and hines big radius, K & N air filter
My first thought was ignition switch. Mine did something similar, though not quite as severe. Test it in your garage with bike running wiggle the switch and see if it changes how it runs. I tested mine on the road, holding it all the way to the left ran fine!! Hopefully your fix is as simple as that!
o codes showing.
