2014 Limited, stuck ignition after reinstall
Old 05-10-2015 | 10:18 PM
Swan99's Avatar
Swan99
Stage I
Default 2014 Limited, stuck ignition after reinstall
Just spent a few hours removing a stuck ignition module from my 14' Harley Limited.
After installing a new handle bar I put the ignition module back in and it wouldn't turn without the key in the far left removal spot, nor would it allow the lock to engage nor would it come back out (don't ever force it or you'll F it up).
I searched the web, called the local Harley shop and spent a lot of time just studying and monkeying with the dang thing, No joy! finally giving up for the Sat. evening.
On Sun. morning after a good nights sleep I went after it again, changing direction. On the 14' you can pull the cover around the ignition off, thank God! because this allows access to the two screws that hold the lower ignition module to the frame, once off you have access to a hole in the bottom of the lower ignition, another thank God here, this allowed my to see that when I put the ignition back in it went in to far and turned under the cam that turns the lock.
When this happens you have to use a bent screw driver to turn the cam in the bottom hole in the lower ignition back into position to remove the upper ignition, then bolt the lower ignition back on and start the process over.
T-town Pig
06-20-2019 11:09 PM
dawroz
07-17-2015 05:47 PM
LMAO36
07-06-2014 11:15 PM
SCOM65
06-24-2011 03:32 PM
Terp84Alum
06-09-2010 06:03 AM
Quick Reply: 2014 Limited, stuck ignition after reinstall
