I need a base map for Thundermax
Im going to try and use TM map 310 as a break in map. Looks about right except my injectors are 4.9gps and not the 5.3 mentioned below:
Developed for use on High Compression 103-106, 107 and 110 Engines with High Compression Range of 10.0 to 10.5:1 with Modified Ported Heads, Similar Duration Aftermarket Cams,
Stock or Modified Throttle Body/ Use on Engines w/ 5.3 gps Red Band Injectors
Lower Idle OK
Lower Idle OK
T-max
GO into the software (map)and change the injector size to the 4.9 !!! load the map and then autotune the idle and just off idle with fan blowing on the motor ..then start riding slowly ...
TOP TASK BAR ... TOOLS-INJECTOR COMPENSATION ....
