Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I found a tuner in my area who comes recommended by several sources one being the service manager at my local HD. I'm going to provide a PC Vision. The tuner charges 350 for a dyno tune, 150 to supply and install exchange cat gutted pipes. From what I've read and discussed with others I feel the price isn't out of line. Comments will be appreciated.
Bill
A little high for the tune. But not too bad. I think 300 is what I have paid here in California, and as you guys all over the country are so good at pointing out we have to pay more for everything here in California.
150 installed for a gutted cat pipe is fantastic. They sell for 125-130 on eBay, not including new gaskets, so that's pretty close to zero labor cost for the installation.
FWIW, use caution when installing a pre-gutted cat. If it wasn't done thoroughly, the motor can suck in some of the cat material leading to not-so-nice results.
not bad price, as usual on this form over kill, a cut out cat is good as long as it is welded up right, just look it over and look into the pipes to make sure they are open. Im sure if the tuner installs it will be ok, I don't think he would install something that will hurt his reparation up.
Not trying to be a smartass but the answer is... the same way the ECM can tell the front cylinder from the back cylinder when the cat remains.
The ECM differentiates between the two cylinders from the oxygen sensors installed in bungs welded into the header pipes. The oxygen sensor reading the front cylinder has a connecter which is gray, while the sensor reading the rear cylinder is black, The absence of a catalytic converter will not interfere with the signals from either oxygen sensor.
Bill
