Tts problem - pls help
Hi
Been reading here for quite a while as a lurker and since last year as a member.
I'm in Australia and sent this msg to Steve cole at tts but not sure if he's on holidays etc.
Can anyone shed some light on this problem.
I have a 2007 flstf with the blue tts. Have used this for a while without issue.
Last night I pulled the main fuse on the bike (orange coloured) to disconnect power as I was changing the fuel level sensor.
Tonight I had reviewed spark data from past flight recording, adjusted spark tables in a cal and tried to flash a new tune but I can't even get ECM info. It says vin not found, ECM pn not found, cal Id not found, and ECM status not responding.
I have disconnected and turned everything off and on and reconnected but nothing changes. I can't flash new tune or even restore my mte file.
The only thing I haven't done is start up the bike as it's too late right now so not sure if the bike even runs.
Thanks for any help.
In case anyone ever has the same issue or interested in the outcome it is now sorted.
Steve was helpful and I think what has happened was when I was fiddling with mastertune last night, I tripped on my laptop power cable and the power went. I uninstalled mastertune and the drivers and reinstalled and it all works perfectly again now. Phew
Steve is pretty good about getting back to his product users. Glad it wasn't something wrong with your bike. Would suck to replace your ECM harness or dongle connections.
Usually when you can't get ECM information it is a cable connection in between the computer to the bike or a driver issue with the computer.
