Vance and Hines fuelpak settings
How's it going guys. I have a unique situation that I haven't seen on the forum. I picked up a used 2007 night Train with big radius pipes, a fuel pack, and a high flow air filter of unidentified make or model. The bike has been running ok but I checked out the fuel pak settings of the maps online and compared them to the settings on the bike. They are significantly different. The only fuel issue i have noticed is a pop when the engine begins to slow down during a neutral Rev. Should I leave the settings, change them to the settings on the vance and hines website, or another option that I haven't thought of yet? The previous owner will not answer his phone or else I would ask him.
You said the settings on your bike are significantly different from the Fuel Pak Factory recommended Setting for your bike. But the bike is running good, I would just double check to make sure that your reading the setting correctly before you start changing things. The settings can be little tricky to figure out at first, maybe your just misinterpreting the settings?
Then if you still want to change things you could write down the settings that you have now and then switch to the recommended settings. Good luck
