Pro tuner reflash aorted
Need some help doing the very first flash on a 2010 FLHTK
After selecting the map to download I click on program ECM then I get Reflash aborted! Check vmi and EMC connections ignition and run switches are on and battery is at full charge. Please retry. - we have tried multiple computers checked for updates, updated Vci , battery is charged (verified with voltmeter) red light flashes on the Orange box as it is supposed to , it sees the vin and I get the green connection in the bottom left corner. Beyond stumped and frustrated....any help is appreciated
Yes it would. The TTS MAP locked the ECM from any other program writing to it. Even the HD dealership cannot access the ECM with their software. This is very unfortunate. the ONLY way for you to unlock your ECM is to put the stock MAP back into your ECM with the TTS Software and the actual TTS dongle. If you don't have access to the TTS dongle (interface) that is married to your bike you are screwed. You will need to get another ECM.
The following 2 users liked this post by harleytuner:
M Oclaf (03-23-2023),
Slingshot383 (03-23-2023)
Hi all, I'm experiencing this same problem. How were you able to determine that a TTS map had been loaded on it already?
I bought my 2012 XL1200N recently, got an orange tuner (unmarried) and cables. It will record data but won't let me load any maps to the bike. I get the "Reflash Aborted" message as soon as I try to run the flash.
Good luck, Jim
The following 2 users liked this post by rigidthumper:
benscratchin (03-24-2023),
thrustinbieber (03-23-2023)
