oil dripping form air cleaner
I noticed this weekend after riding for almost 2 hrs on the highway got home parked the bike went inside for a few and when I came back out there was oil that had dripped from the air cleaner onto the motor. The bike ran fine and has no mods other than slip ons and a k&n. Anyone have any ideas? 2009 SG
The way it was explained to me by my tuner is the emissions system sends oil from the top of the cylinders back into the throttle body. The oil that is not pulled into the cylinders settles into the air filter. If you pull your filter off, you will find a lot of oil on the throat of the tb and needs cleaned off. If you have a filter like a K&N, you can clean it out. The stock filters get saturated on the bottom side and need replaced. If you will look on the top of the filter back plate there is a tube that goes to the top of the head. This is where the oil comes from. There is a way to modify and reroute the oil to exit via a drain like the evos.
My 08 Ultra had the same problem when I first bought it used. I'd go for a ride and come back with oil spots flickered on the side cover, and front of the right saddle bag. I took the air cleaner (stock) off and the inside of the cover was covered in oil and so was the surrounding area. To make a long story short, I bought a Screamin' Eagle air cleaner, installed it and that was the last of the oil problems dripping and spraying on the right side of the bike. Now, the oil that was spraying out is being sucked into the cylinders. It works the same way any PVC, (positive ventilation crankcase) valve works in any car on the road.
That stopped the oil problem, but I went a little further and replaced the breather elements, (they were a little brittle and they had started to deteriorate) and one-way valves in the upper cover housing. The elements and valves didn't change anything or do anything to the bike performance -wise, but it gave me piece of mind after I found out Harley had two upgrades for the valves since my bike was manufactured only 6 years earlier.
After I installed the SE air cleaner I did notice the engine ran smoother and a little quicker responding when I gave it some throttle. The down side is that the bike ran a tad hotter with the SE air cleaner. To compensate for the increased heat I'm looking into an XiED which will also give me even more throttle response. One thing leads to another, but with any luck it will end there. Hope this helps.
While I appreciate all the fancy plumbing jobs and aftermarket devices to reduce/eliminate this problem, there is an easy and inexpensive option that may work for others.
I've done the following on my 2012 103 UC stock air cleaner...
(1) pull the little black rubber tubes from the rear of the AC but leave them attached to the back plate
(2) plug/cover the two holes in the AC from the black tubes
(3) wrap/secure oil absorbent material to the bottom of the black rubber tubes and let them hang behind the AC. If you feel the need to get fancy and spend money, use an open element fuel filter and just jam some material into it for added absorbency.
(4) replace AC
Now remember, I'm using a stock AC and football cover so none of this is visible.
This has worked for several thousand miles with no issues. I no longer have oil in the AC or the intake. I change out the absorbent material about every 2 or 3 thousand miles but have never found it soaked enough to even come close to dripping. And it takes all of about a minute to change out the material.
Total cost...maybe 25 cents as I had all the materials on hand.
(4) replace AC
