Heavy Breather VS Ventilator
Received 4,228 Likes
Check out the details at this LINK
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
although I agree with Kevin above, and to the OP's question the difference is simply not important unless you're building a BIG INCH motor. Either of these will flow much more air than your motor is capable of breathing in/out. Boils down to preference. Also what Kevin eluded to with the oil ingestion, if you don't go with Kevin's Outlaw A/C then do yourself a favor and get those oil passage returns venting out, not into your throttle body. Here's a recent pic of 2012 103" motor with 9k on the clock. Pretty amazing what get's caked up on those pistons with that little mileage on them and the oil passage returns going back into the throttle body all in the name of EPA.
2012 FLHX 103" 9k miles. Oil return vented into throttle body.
Agreed, almost all aftermarket A/C's will flow more air than the 103's can eat, but HOW the air flows does make a difference.
The Dyno above is of a stock 2012 103, but HOW the air flows makes a difference as you can see.
Below is another chart of a comparison between the HB and the 636v, both A/C's can flow Far More air than the engine can eat...but HOW it flows makes a big difference.
Great picture showing what happens to bikes out of the factory or running most aftermarket air cleaners!
