Harley-Davidson Street 500 and 750
RPMs Running High
Old 08-09-2023 | 01:46 PM
wesleyfouse's Avatar
wesleyfouse
Stage II
Default RPMs Running High
Hi all,
I recently started having an intermittent issue on my 750 where the RPMs will shoot up to over 2,000 when the engine is idling, almost as if the throttle is stuck. This happens in both neutral and first gear.
What's odd is that it doesn't happen all the time sometimes the bike will start and run completely normally. Other times the RPMs will shoot up 15-20 minutes into the ride and just get stuck.
Any idea what might be happening?
Here's a video of what's been happening:
File Type: mp4
Old 08-09-2023 | 04:09 PM
smitty901's Avatar
smitty901
Year of the bike, mileage any work you may have done would help
Have you checked for codes?
That bike use cables not TBW. One cable it go the other is return. Good chance one is sticking and or started to wear. .
First I would carefully open the housing up and lube cables And the bar a little under the grip.
Jacksonysk (11-10-2023)
Old 08-09-2023 | 08:46 PM
wesleyfouse
Stage II
Thanks for the response! 2019 Street Rod 750, 12,700 miles and no work that I've done, though the previous owner added a new exhaust, I believe. That sounds pretty reasonable. I will check the housing and try lubing up the cables and the bar and see if that helps at all.
Haven't checked for codes yet, but that will likely be my next step if this doesn't solve the problem. Many thanks!
The following 2 users liked this post by wesleyfouse:
M Oclaf (08-09-2023), smitty901 (08-09-2023)
Old 08-09-2023 | 09:24 PM
smitty901's Avatar
smitty901
All ways Check codes first thing. It is in your best interest to do so.
Pugslycat01 (10-13-2023)
Old 08-13-2023 | 12:56 AM
2AMGuy's Avatar
2AMGuy
I'd suggest that you start looking for vacuum leak around the carb and intake manifold and seals,
The fact that it idles up and down without you touching he throttle (to me) excludes a cable issue.
Some EFI bikes may have a high idle if the ignition was turned off before the engine got back to the proper idle RPM and some people claim that than condition can be corrected by turning the ignition OFF and ON three times but I've never had to do it myself.
Let us know what you find.
The following 2 users liked this post by 2AMGuy:
Pugslycat01 (10-13-2023), Ronin2911 (09-04-2023)
Old 08-13-2023 | 05:32 AM
smitty901's Avatar
smitty901
Has not been a carbed HD sense 2006. The street does not have TBW.
The Street is EFI but uses cables. The Throttle grip and housing is cheap construction and is some what know to get a sticky spot in it. Absent of any codes it is almost a sure bet cables and or grip.
When dealing with a street you have to think outside of the normal for HD.
Old 09-04-2023 | 10:23 AM
Ronin2911's Avatar
Ronin2911
2nd Gear
Just went through this with my 2018 Street Rod. ECM coded with P0507, and a noticeably higher idle. I have a great dealer; he diagnosed the issue as failing intake gaskets. A bit early for that, but things happen. Gaskets replaced for under $200, and the bike is great again.
The following 3 users liked this post by Ronin2911:
2AMGuy (09-04-2023), Pugslycat01 (10-13-2023), smitty901 (09-04-2023)
Old 09-04-2023 | 10:58 AM
smitty901's Avatar
smitty901
Always good to check codes first.
If you own a street you have two options. Get good at fixing it your self or sell it HD dealers are backing away for it .
And HD i not to excited about supply parts going forward.
Old 09-04-2023 | 11:02 AM
Ronin2911's Avatar
Ronin2911
2nd Gear
Except I own a Street ROD. Completely different bike, despite a resemblance to the XG. My dealer has two master techs who specialize in Street Rods, and I’ve never had a supply issue. At least not yet. However, if Harley Corporate ever revives the Street Fighter lineup, especially the Bronx, then I’m there.
JakeC7R
10-05-2021 02:17 PM
Chrisfxdb
11
06-18-2020 11:52 PM
sangbro
2018+ Softail Models
04-15-2020 05:35 AM
CliveP
09-30-2018 12:11 PM
pigpipes
09-04-2013 10:03 AM
Quick Reply: RPMs Running High
