2015 750 stuck in first
Greetings, trying to help my brother trouble shoot an issue with his 2015 hd street 750.
Stuck in first, shift lever seems to be loose internally? Clutch is adjusted and seems to be functioning just fine. Suggestions?
( first post here, apologies if i am being the fng )
yes, shift lever moves, will ask if the shaft does ( brother if your reading this: join the convo, lots of knowledge freely shared)
I think the shift shaft moves as much as it normally would; the shift arm doesn't feel stuck, it just isn't grabbing anything inside the transmission. Everything looks like it's moving correctly on the outside.
The clutch seems like it's working fine. The bike is still when the clutch is held in, but if I let the clutch out the bike is stuck in gear. Worth noting, we did disconnect then reconnect the clutch cable when replacing handlebars last weekend.
I've tried letting the clutch out a little while trying to shift, moving the bike a little while trying to shift, and nothing's worked so far. Could it be a problem with the shifter pawl? (I'm pretty new to the maintenance side of things.)
Thanks for your help!
