Street 750 clutch adjustment
#31
gotta have that service manual, for each and every bike i've owned......... i read somewhere on one of these forums just lately that someone was going to replace their clutch with a barnett setup. they mentioned some other brand, but i remembered barnett 'cause they've been around for a few years
#32
#34
#35
The following 2 users liked this post by Red Glide:
Pugslycat01 (02-22-2021),
RoM (02-21-2021)
#36
#37
Neutral rattle on HD 750….
Just purchased a 2019 street 750 with 2500 miles. Driving it without my full face helmet I noticed a slight noise that is eliminated when I pull in the clutch (even a little bit). Should I consider it normal or is it some kind of problem with the clutch/gearbox?
#38
The clutch adjustment is more of just a cable adjustment. It must be done right of the Xg clutch will not last.
I will post the steps latter today if you check back. I have posted it in this forum before so a search may shown it.
You must do this by the book.
AT 2,500 it is still new clutch may need adjustment.
In Fall we replaced the first 750 XG clutch with 3 of the here. It had just of 50,000 miles miles on.
The signs were simple. slipping and no amount of cable adjustment would correct it.
#39
Barnet clutch
I put new clutch in but still was slipping and Harley said was common problem. So my mechanic put a spring and bottom of clutch cable where connects to the clutch and solved the problem. I guess it wasn’t releasing all the way when releasing the lever
QUOTE=smitty901;21199116]The clutch adjustment is more of just a cable adjustment. It must be done right of the Xg clutch will not last.
[/QUOTE]
[/QUOTE]
heavymetalthunder
05-30-2008 07:49 PM
