Fuel Pump Recall
The recall first tries a fix. If that does not work a new redesigned pump is needed. The fix is a ECM flash and a check of a fitting at the bottom of the existing pump. It is like a grommet and has come loose on some units.
The fix did not work on mine and the dealer was authorized to replace. They must try the fix first and it works the majority of the time.
I put over 2,000 miles on mine since the replacement and it works great.
Thanks for the info!
Harley-Davidson's Street Series is Being Recalled
https://www.hdforums.com/articles/ha...ries-recalled/
