Trailer wiring question
I just bought a legacy trailer that came in today, and I also ordered a plug and play wiring harness from them that they said would fit, the salesman said that the trailer had a flat 5 connector on it and that the harness was designed for a 5 connector, but when I went to in stall harness and looked at the trailer it has a flat 4, would like some input from anyone that has used the plug n play and had this problem, I do know that some places sell a 5 to 4 connector but I live in a small town and everyone I called don't have them, I was planning a 3000 mile trip leaving on Tuesday so would really like to get it going before then.
Also any pics of how the wires were routed would also help.
Thanks
Wojo
Thanks
Wojo
You can buy this from Amazon:
If you need one and can't find it, make your own. Buy a 5 wire flat (female - trailer end) and a 4 wire flat (male - vehicle end) pigtails.
Wire colors are green - right. Yellow - left. Brown - tail and white - Ground. Connect the pigtails and secure them. Do not completely secure the brown until you know about your trailer accessories. So, for brown you can twist the wires together (but don't tape them yet.
You should be left with a blue wire from the bike - this is for accessories. If there are no accessories or side lights on the trailer, you don't have to use this. Just tie it off and secure.
If you do have accessories or side markers, they can be separate (using the blue wire) or tied to the tail lamps. Since the trailer is already wired for 4, they are already tied to the tail lights.
Now, you have a convertor connector.
Plug the 5 flat female into the bike and plug the 4 flat male into the trailer. You should be good to go.
Plug the adapter you are making in to see if the lights all work on the trailer. If they do, just leave the blue wire (and secure it). If they don't, then connect to blue with the brown.
This is easy to make. And just so you know, on my trailer, I had the blue wire separate because I had an of/on switch that controlled my accessories lights. So, who wired your bike -and what is the blue accessory wired to?
Good luck
Good luck
You can buy this from Amazon: Amazon.com: Hopkins Plug-In Simple 47515 4 Wire Flat To 5 Wire Flat Adapter: Automotive
Good luck
Good luck
Wojo
dirtdobber
02-28-2014 03:26 PM
