Harbor Freight Trailer Questions
I spend a lot of time on the road with my service truck, which is 100% necessary in my line of work. I'm working in Houston for a few weeks, and it would have been so nice to have been able to bring my bike along for the trip. There are also other times when I have to drive the service truck, but would be able to ride in my spare time. Could even leave the service truck on site at times, and ride everywhere else I want to go.
I'm looking at the Harbor Freight trailer, which is rated for a little over 1700#. Thinking of welding in a channel, and decking with expanded metal, then enclosing it somehow.
Anyone built a bike trailer with one of these as a base?
The HF fold-up (the one I assume you're looking at) trailer looks awfully flimsy. I'd peruse craigslist for a 5x8 trailer. I've hauled my WG on a 5x8 with fold down ramp. I had about 6"-8" between the tip of the rear fender and the fold-up ramp.
One thing, the trailer I used had expanded metal for the flooring and I can tell you from experience, the metal has too much give. My rear tire would sit between the rails (frame supports) and bow the metal a good bit. Unless you take some measurements, and install some reinforcements (rails) to cover the area where your tires will sit, I'd advise against expanded metal.
I wasn't able to do that with my borrowed trailer because, well, it wasn't mine to alter.
If I were in the market for a trailer, I'd by at least a 10' long trailer to allow for a wheel chock to be installed.
Here is one on CL that is very reasonably priced in SA.
http://sanantonio.craigslist.org/cto/2542197195.html
No, not the folding trailer, the heavy-duty trailer. The expanded metal was for decking in non-load-bearing areas. I would use a full-length steel channel for the bike, and reinforced plate for other load-bearing areas.
I'll have a look at the one in SA. Thanks!
ETA: That's a nice one for that price! If I weren't working out of town, I'd run to SA and have a look with cash in hand.
I trailered my bike to get tuned after I did my cams. Wasn't 75miles from here to Winston-Salem, NC. As I got off the interstate, I notice the trailer was rockin and rollin. Pull over, and again another tire had disintegrated. Literally. I limped to the tuner. Removed the bike, let him start working while I found a place to buy a replacement tire for the ride home.
I think what I'm saying is don't get the HF trailer. Look elsewhere for a better-built trailer for your bike.
I saw one in Dallas one the side of the road, with a broken axle.
I would look on craigslist for a used trailer. You can fine an enclosed 5X10 without a ramp door for around $1200, if you look long enough.
A well built open utility trailer can be had for $600 all day. If you are going to pull ot a lot, I would look for one with an ez lube axle. The issues I have ever seen with a good utility trailer are wheel bearings failing. That is because they were not lubed properly. Other than that, check the bolts for the springs/axle. Sometimes they come loose.
