Trailer info
Trailer info
Picked up an ALUMA MCT trailer. Plan on pulling with my RK.
Trailer has a wierd connector on it. I may need to add a pigtail or adapter to connect to bike, The connectors a 6 position with wires to each pin. The tailer has LED lights. Am I lacking the other half of this connector to pigtail to the bike?
I Haven't gotten a hitch or harness yet for the bike. Trailer has the swivel hitch.
Thanks to all replies
I don't have a trailer but I have been looking at them for a while.
I do not know what your connector is called but if you want to wire your bike to match, you might want to take a copy of the picture you have to a few places that sell trailers and hitches. They might be able to identify it for you, if no one on here is able to help.
You'll have to figure out which wire goes where (left turn, right turn, stop, tail, etc.) and wire the connector on your bike to match.
Another alternative would be to just replace it and buy a new one for both your trailer and your bike. The picture looks like a couple of the round covers for the plugs are split. If you buy a new connector you could get one that more closely matches your bike or one that has a water cover for when not in use to help keep the connectors from corroding.
Another suggestion would be to look at an item called an isolator. Some bikes electrical systems cannot handle the extra load of the trailer lights. An isolator takes power straight from the battery to the trailer lights and the isolator acts as a relay so that the extra current does not overload your bikes wiring harness. At least that how I believe they work, someone will probably correct me if I am mistaken.
Hope this helps.
Hope this helps.
Thanks Morris.
I have to get the isolator and hitch still.
THe pictured connector is wired to about 4 inches shorter than the end of the tongue of the trailer. This led me to think there should be a (short) pigtail to complete the length to the bike. I found an aluma dealer not too far away so I was headed there.
Thanks again
Thanks again
Hey Tim,
I am new to the motorcycle trailer world myself and don't know much about the connector you have there. I do agree with Morris that you might be better off replacing the connector on the trailer with a new connector when you wire up your bike for the trailer.
If you are looking for a hitch I just got mine from MCHITCH and am very impressed with the quality. The price was right and they were great to work with.
Good luck.
Craig
Good luck.
Craig
Tim I posted my trailer on here recently. I just used a simple 4 wire flat connector on the trailer and bike. Simple tap into harness under the seat. You will need a test light. Change bulbs to L.E.D. which fit right in bulb socket and you won't need any special relays or isolators. If you don't feel comfortalbe doing this, I'm sure any bike or car repair shop would do it. Best of luck.
