Trailer wiring harness with isolator
Anybody use this trailer wiring harness with isolator? Didn't see Open Road Outfitters on the Sponsor list and would like to hear if anybody has had any luck (good or bad) with their products. Says it's a complete Harley wiring harness for 5-wire trailer and includes plug-in subharness for your bike and relay package.
I have no opinion and was in the same boat. I just pulled the trigger on the Khrome Werks hitch and harness w/isolator & connector. $98 for the HD 5 wire harness/isolator/connector from Phat Performance Parts.
Complete Harley Wiring Harness for 5-Wire Trailer
$99.85
A relay-isolation harness is a good investment if you're planning to pull a trailer. This setup allows you to drive a set of trailer lights (standard bulbs or LEDs) without affecting or loading the bike's signal circuits. In the event that a short develops in the trailer wiring (typically in the plug area), an inline fuse in the relay package protects both the bike and trailer. Your bike's lights will remain unaffected and continue to work. Simple plug-n-play installation makes it a snap to install.
I'll have to check out Phat Performance Parts. I also ended up with a Khrome Werks hitch. The wiring harness I was looking at is from:
$99.85
$99.85
" 1 of : Khrome Werks 5-Pin Trailer Connector Kit - 96-10 FLT Touring Models with Isolator Module - (exc. 2010 FLHX, FLTR; 09-10 SE CVO)"
HTH
BinIdaho
03-29-2019 04:01 PM
