Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Fuel Motos' Doing Some Cam Testing
Old 08-25-2010 | 04:42 AM
msocko3's Avatar
msocko3
Default Fuel Motos' Doing Some Cam Testing
I was browsing the Touring section and bumped into this thread... https://www.hdforums.com/forum/touri...fuel-moto.html
So far its an interesting read, will be more interested to see what the TW-555 cam does with the bottom end torque. For those who are interested in the specs you can find them here http://www.woodcarbs.com/06-11cams.htm
Old 08-25-2010 | 04:52 AM
Casper's Avatar
Casper
I read the post, now my head hurts.....
Old 08-25-2010 | 10:04 AM
Mr. Wizard's Avatar
Mr. Wizard
The main different in the two cams are lift and duration but they don't give the overlap. The intake opening and closing are only a degree difference so with the new lift there should be a bit of a torque gain on the 555's especially in the low to middle R's.
The one degree late closing should have a good effect on puddling and that is a fine line to walk with that high of a lift with just a touch more duration.
Looks like they are trying to find a middle road cam to keep the torque band longer in the RPM's without head work?
Old 08-25-2010 | 10:34 PM
Mr. Wizard's Avatar
Mr. Wizard
It looks like you guys may want to reconsider the 6 for the 555. The numbers that they came up with aren't that much more but if you want to replace your cam you may as well use the best one for the job. The 96 isn't that much different than the 103 and it doesn't look like the stock compression will be an issue.
For those using the SEST or TTS a good starting map would be for the 203 cams ( intake opening and closing 18/42- 203 and 21/41-555) then set your CI and VE's to compensate.
Old 08-25-2010 | 11:08 PM
T K Glider's Avatar
T K Glider
HuH?........................
Old 08-26-2010 | 05:51 AM
oldmsocko's Avatar
oldmsocko
I'm confused. Are you saying folks should consider the 555 instead of the 6??
Old 08-26-2010 | 07:23 AM
msocko3's Avatar
msocko3
It's looking like Mr Wood came out with a new grind that is a touch better than the TW6-6. If I already had the 6 I wouldn't change them because the difference between the 2 isn't enough to justify the cost or hassle. If I was looking to buy I'd be leaning heavily towards the 555. Nice this is any changes you or I make will be this winter so there is time to set back and study it a little more before parts are ordered.
Old 08-26-2010 | 07:33 AM
Boom's Avatar
Boom
Didn't Bob Woods originally recommend the 6-6 for the TG? Now my head hurts!
Old 08-26-2010 | 07:58 AM
Mr. Wizard's Avatar
Mr. Wizard
What Woods did was to make an improved cam like HD made an improved front belt pulley. Changes like this happen all the time in development.
Woods split the difference between his 5-6 and the 6-6 and called it the 555.
If you remember the Woods conversation reported here... "the 5-6 would be a good cam for the TG 103 but the 6-6 would be a better cam".
Now they developed the 555 and just taking a quick tour of the 555 and the dyno sheets by FM there is just a tweak bit more T & H with the 555 and the T came in just a touch earlier. If you look at his graph you will see the "Harley Dip" (2800 to 3200 RPM's)was smoothed out as well. The "Dip" is where you guys need the extra T.
One thing to remember... this was done on a 96" motor with a PCV on a dyno. Your results will vary. Either cam would be a good cam for the TG owner who wants to pull a heavy load or simply zip around town dressed down.
Old 08-26-2010 | 02:36 PM
msocko3's Avatar
msocko3
Mr Wizard addressed it very well.
VTL nut
11-11-2013 09:45 AM
natural gasser
Exhaust System Topics
05-02-2011 10:14 PM
cardboard
10-02-2010 06:15 PM
scottyd
08-05-2010 01:28 PM
bemisbunker
01-14-2006 09:32 PM
Quick Reply: Fuel Motos' Doing Some Cam Testing
