Oil Temp gage
The temp sensor which goes into the pan will show pretty much the warmest vs the one for the dipstick due to residence time in the pan and working its way through the baffling. I've never bothered to cross check the pan temp sensor vs what one could read from the dipstick hole. Might be awhile before I ride my TG again but maybe my dad might get chance to get a temp gauge reading vs a reading at the dipstick. I have a lab quality digital probe in my toolbox that can be inserted in the dipstick hole.
Okey doke...here's the answer from my HD Service person on the dip stick issue: I can use the LED one, but it is only for reading oil temp, not for measuring how much oil I have. To measure, I would have to take out the 'fancy one' and put the stock one in. Yeah, sure I'm going to do that.
bdn....you've got mail
Temp Difference
Yo Coupe! My dad and I went for a little putt this morning for breakfast. When his Harley Temp gauge read 220 degrees the temp probe I stuck in the dip stick hole read 175 degrees, pretty good difference between the 2. If you look in the service manual you will see how the oil travels through the baffles and pan.
Had some techs tell me telling me there is such a thing as running to cool but in no fear of that with the Tri. I used the termostat for the old cooler for the Jagg so it is going to warm the oil up to operating temps before passing it through the cooler. The moisture they are talking about burning off should take place at 190 or 200.
My TG seems to run best at about 190-200. When it's in the 230-240 range is when I start to lose low end grunt. It may take 20-25 minutes for it to reach that temp from a cold start.----even in this hot weather.
Sluggish
I was wondering if anyone else had experienced this, mine is not sluggish to to a large degree but you can tell the Tri is more responsive and you get a more crisp throttle response 190-210. I have to use a little more clutch sometimes pulling out when the oil temp is in the 240 range.
