Brakes on a trailer
Brakes on a trailer
Ok i am building a pull behind trailer in which I am using wheels that I bought at a swap meet for 125.00 each. I then made an axle for the trailer frame. After reading some posts about pull behind trailers everyone talks about the stopping distances increasing with the additional weight.
My question is this if I install rotors on the wheels and the proper calipers could I go to the rear wheel of the bike and place a ''Y" or some sort of a splitter then attach brake line to the back of the bike. From there have the brake lines from the trailer wheels come forward to the hitch area and connect to the bike. I am sure that I have enough clearance between the wheel and the fender as well as the frame.
Any thoughts would be nice.
Thanks Don
Thanks Don
Thanks Don
Thanks Don
and re-connected
2nd problem is the length of line and hose for the pressure. Im pretty sure the rear master cylinder wouldnt handle the volume of fluid needed to even get the brakes on the trailer to work. At best your rear brake pedal would feel spongy
If you had used a axle setup from a small trailer with a inertia brake system then you might be able to get them to function. But even then having brake on that small of a trailer could be overkill and make for a situation when stopping you dont want
If your set on this I would suggest you look into dual six piston front brakes for the bike and good pads such as EBC. I use EBC carbon fiber pads on my brembro calipers on my trike. They dont last as long as the stock pads but give great stopping friction and to date havent faded on my trike when I have had to make a hard stop. 90% of my stopping is done with the front brakes
BTW, nice job on the trailer. The back of it looks great
I have towed a trailer all over the U.S. since 2003 and although there is a slight difference in stopping distance during hard braking it has never posed a problem that would make me want brakes on the trailer. If you were going to install brakes Electric, like the kind on an RV, would be the only way to go.
