117" in my trike
Heres a copy of the dyno results from Tilleys HD. Unfortunatley the dynos O2 sensor wasnt working correctly and even though they are a seller for TTS they hadnt made a run using a TTS Mastertune there Tilleys had to use the sniffer up the pipes instead of using the O2 sensor setup. But Tilleys did get me a base map close for me to tweek with "alot of help from Mr Wizard on here" that its making some good torque which is what I wanted...... Factor in the parasitic torque loss through the axle to the right rear tire, the torque would be 125-130 ft lbs on a 2 wheel bike..... Its pulls like a gorrilla on steroids
Just so you know, this dyno run was made with the bike AFRs set @ 14:6
(i'll pay for that one)
