Heat source has moved
Hey, I recognized that guy; I’ve seen him every morning for the past 5 years standing at the freeway entrance with a cardboard sign that says: “Out of Gas”…and every morning I think to my self…boy, I sure am one lucky guy…this poor guy gets worse gas mileage than I do!
Back on topic
This reinforces what I've been saying for years, "if I had any idea I would live to be this old I would have taken better care of myself".
I think I have it confirmed there is no safe guard shut down to protect against catostropic heat related engine failure on the Tri Glide's. The EITMS and a program that forces you to idle when you run the engine to hard are what safeguards Harley built into them.
Which takes me back to my position it is better to get the Tri cooled down below where the EITMS kicks in just to be on the safe side. 285 is scary close to the 300 Degree temp, where even synthetic oil starts to break down. If we can get these things to idle in mid summer heat, down town without the EITMS kicking in we should derive a little extra margin of assurance "peace of mind that we might be able to get some extended engine life without a rebuild".
I'm sure Harley engineer's know more about the heat threshold or upper temperature limits before an engine starts to fail but to me they are pushing the envelope! Again I was probably influenced by my ol carbureted 03 FLHT, "pre EPA Harley".
The new 2010 EPA Clean Air Standard forced Harley to inadvertantly raise this heat envelope in order to comply with the new standard. MOCO will tell you they are within generated heat limits at idle with these new touring bikes. It is my contention they are not but time will tell I guess!
So what is the consensus here? Heat sheilds on for scooping air or off so air is not trapped around motor while sitting in traffic?
Does wrapping the header pipe to keep heat in the pipe and increase exhaust gas velocity cause the motor to run hotter or have little effect on motor temp and just help rider temp? at 88 deg. I have seen 240 in stop and go creeping traffic. My ETMS was cutting in some times.
I think you should speak to this guy. He is X HD Customer Service. this guy..
Talk to the Hand
I was given a set of hip boots and referred to this guy when I complained about the heat problem, just before he left MOCO to work as a lobbyist for the Sierra Club.
He was bulls#*tin us about the motor control unit, it would take an inverse phase angle and inductive reactance coil coupled with a flux capacitor if the transformer was a Y configuration with a viarable impedence control mounted before the motor if was a universal type. Triac's, diac's or other semi conductor devices without a .0001% tolerance at 20 ampers would still make the whole device run like a Tri in downtown L.A. traffic on a 110 degree plus day.
In short it was not designed to run hot, global warming just makes it seem hotter and Al Gore keeps ragging about it or we would not even think about it, or have to take the heat shields off, if we just quit overthinking it and put your footpegs on the handle bars!
