Oil Pan Question
1 Post
Baker +1 Oil Pan Observtions & Illustrations
It was a dull Sunday evening in December. Living only 9 miles away from J&P Cycle, I often stop during slow times to get up close and personal with any large part or parts that I am considering purchasing. I'd just snagged a popular Crane cam grind, 4 HD wrist watches, a bodacious air-horn, and had looked over an S&S ignition system, when I asked if there were any Baker +1 Oil Pans in the warehouse. The 2 courteous staffers were as enthused as I was, as we unboxed a black wrinkle finish "BD-5QTB". Nicely packaged and VERY nicley built, we were all impressed as we looked at the oil routing and baffling, all cast in heavy duty, high quality A356-T6 Aluminum. I bought 2 of them for Christmas gifts, and one has been a comversation piece in my dining room for some time. Attached are 5 views. View "C" allows you to see how the oil input & output routing is seperated, while "D" and "E" shows the thorough baffling from front to rear of the pan. There are also several views w/ a ruler to give you some limited concept of dimensions (as well as my cell camera could provide). Weighing a good 10 pounds (estimate from BR scale), this thing is Robust, and the sheer bulk of the pan, baffeling, and ribbing will definately absorb and should dissipate a lot of heat (I wish I could get one into the Lab where, as a 25 year engineering veteran, I did such studies for Boeing, Airbus, and the military). There's even a Heavy-Duty structually located integral boss for mounting an Alloy Art TXR Stabilizer ! An 8 page installation pamphlet is included, user friendly. A 5/8 inch socket, 3/16 Allen socket, Torque wrench, and 3/16" allen wrench are needed for installition (plus Blue lock-tite). Included are a heavy duty Pan gasket, elbow fitting, 3/8" NTP Plug, Hex Zero-Leak Drain Plug, and 12- 1/4"X20X3.5 bolts. Applications listed are for 1993 through 2008 FLH only. Their tech dept. is listed, 877-640-2004. I've attached five .JPG files, the last of which shows my Buddy Clyde's approval for the unit's use on his 2008 105th Anniversary Ultra Classic. Mine is going on my 2008 FLHTCU Moto-Trike conversion, along with an HD Touring Oil Cooler, and a LaNale Engineering engine cooling fan (mounts in place of the stock Horn). Should help out with the bore kit's 10 to 1 compression, cams, trailer hauling, etc. We're ready to tackle installation on Clyde's Ultra, I'll keep you posted as to any difficulties we encounter on the way. Please advise if you need more photos etc., I'll do my best. I hope this helps answer questions for interested FLH owners. Ride Safe, and keep that motor CoooooooL !
Maybe the engineers at Baker will read some of these posts and get off the dime and design one?!?
