Suppose our Engines did blow
Each motor will always perform different and will last shorter or longer then the next one. How you ride, where you ride and how you service are some factors for when you could have some kind of failure. Im at 29k on the clock so far in less then 2 yrs. Have I had problems, yep all have been fixable.
Even the best built motors are only as good as the parts it is put together with and how its used. The variables can drive yah nuts thinking about it...lol
I just remind myself, that is man made and because of that its bound to stop working sometime.
When I mention the heat issue to local service techs I get, "they all run hot". "The motor company has tested this engine design in all conditions."
I've got the 5-year with only 550 miles on it so far. I live in a temperate climate with moderately hot temps in July, August. But in three years I'll be moving to west central Florida where the summers could be a bit more brutal.
I think we're OK
With all due respect to those who know more than I do about engines, I think we're OK. The second biggest reason we all like HD is that their engineering is pretty good. I know our trikes run hot. but I truly believe they can handle the heat if we can. I can, and my wife can.
