Hacked, Conversions and Trailering"Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts"
A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Any one use the extra long oil filter part #63812-90 thats for the fxds. I was thinking about using it as its a lot longer will hold more oil is black should dissipate heat better then the stock chrome one. Just a thought.
Im using the KP Engineering oil filter. Its made from billet aluminum which dissapates heat faster, plus you can clean the filter and reuse it. It also has a small magnet on the filter insert >> http://www.kandpengineering.com/index.shtml
If that filter doesn't fit you could use the black filter instead of the chrome one. I use the black filters because I hate polishing the chrome one and the black is cheaper.
